Use this document to create a storyboard for presenting an analysis process, explanations, calculation steps, and charts.
Before You Start
- You have logged in to FineBI Next.
- You have access to a project where you can edit content.
- You have prepared analysis steps or charts that you want to present.
What a Storyboard Does
Use a dashboard when you mainly need to display charts.
Use a storyboard when you need to explain how an analysis conclusion is reached. A storyboard can include text, analysis steps, calculation explanations, and charts, so it is suitable for an analysis report.
Creating a Storyboard
- Open a project.
- Click +.
- Select Storyboard.
- Create a blank storyboard.
Screenshot needed: Create a storyboard from a project.
Adding Text
Add text to describe the background, conclusion, or explanation of the analysis.
- Add a text component to the storyboard.
- Enter the text content.
- Set the text style, such as heading level, color, and alignment.
Screenshot needed: Add and style text in a storyboard.
Adding Analysis Steps
A dashboard usually shows final chart results. In a storyboard, you can also add analysis steps and show the result data of those steps. This helps viewers understand why the analysis result is reliable.
- Click Analysis Steps.
- Select one or more steps. To select multiple steps, press Ctrl or Shift.
- Drag the selected steps to the storyboard.
- Save the storyboard.
Screenshot needed: Add analysis steps to a storyboard.
When viewers open the storyboard, they can expand an analysis step to view its result data.
Screenshot needed: Expanded analysis step in a storyboard.
Adding Charts
Add charts when you need visual evidence for the analysis conclusion.
- Click Charts.
- Drag a chart to the storyboard.
- Adjust the width and height of the chart.
Screenshot needed: Add a chart to a storyboard.
Screenshot needed: Adjust chart size in a storyboard.
Result
After you complete the configuration, the storyboard presents the analysis process and final results in a report-style layout.
